Thanks for that thorough explanation, much appreciate the time you put into it.
And your suggestion about rotating worked fine. Just managed to squeeze it into the limited 200 x 200 valid area. (BTW, even with Snap enabled I found it difficult to get the model back to its original zero angle. Is there a tool I’ve missed?)
Could you explain a bit more on that final point please? How do I now proceed?
- You must alter that file to get rid of the clip areas.
And are the clips securing the glass in the same positions on the Ender 3 and the Ender 3 V2?
Also, I’m puzzled why there is still no specific profile for the Ender 3 V2?
The print failed to adhere properly, so now pursuing that unrelated issue!
Terry
GregValiant 1,115
Not Cura - Creality.
Creality calls it a 220 x 220 build surface and that's what "Trouch.Com" (the developer of the Creality printer definition files) put in for all the Ender 3's. In addition, there are "disallowed areas" defined for the clips that hold the glass down (there were on my Ender 3 Pro). Another thing that affects the size is skirts and brims. If you look you will see that on the left and right of your Cura build surface there are lighter gray areas. Those are there because you have a skirt or brim defined and Cura is reserving those areas. In the front and back you see darker gray areas that are defined as "disallowed areas" in your printer definition file and are not affected by skirt and brim settings.
"default_value": [
[[-117.5, 117.5], [-117.5, 108], [117.5, 108], [117.5, 117.5]],
[[-117.5, -108], [-117.5, -117.5], [117.5, -117.5], [117.5, -108]]
