Posted
· Help - gaps in top layer and around outer walls
One other issue to note. I performed my extruder calibration using Repetier host. I measure 120mm on filament and command feed of 100 through Repetier manual controls. Turns out perfect every time with 20mm of filament left over. Now if I do that same test, but use the controls of the printer itself it over extrudes by 5mm. ?? Am I missing something here? Double checked my eprom e steps setting and nothing has changed. I’ll post some pics later on this evening.
frankis1776 0
