I'd never seen such an arrangement for the temp sensor in an UM-2.
I'll guess this is kind of "hack", -in order to avoid open the whole printer in order to change the PT-100 temp sensor.
You have to order a new original PT-100 sensor for the UM-2, this as the sensor come as a complete unit with wiring directly connected to the sensor and a connector in the other end -to be installed into the main PCB (located under the printer).
Did you managed to remove the old PT-100 capsule.
(PS., there is a kind of metal filter seen on one of the cooling fan, never seen this as well -would not this reduce the airflow for cooling the "printing object"?)
Anyway, good luck in changing the temperature sensor..
Torgeir 250
Hi @skint,
Thanks
Torgeir
skint 61
Hi Torgier
Thanks. I was assuming I would have to order the whole part 😞
This is one of the first UM2s. I bought it not long after release date.
I haven't tried removing the PT100 yet.
The fans were fine. Intact, until I had a major blockage which caused this damage, this printer has been brilliant for years!
thanks for your help
