Thanks for the reply.
As you can see, I've unchecked the box for Support. Does this not disable the second extruder?
Greg
Greg
no. Go into PREPARE mode (as opposed to PREVIEW). Just below the bar with PREVIEW is a bar that shows your extruders and materials. Click on either extruder (doesn't matter which) and it pops up a control with 2 tabs. Choose the tab for the extruder to disable and uncheck it. This is the same place where you can choose filament type/color/size.
nallath 1,124
What do you have loaded in your second extruder? Try disabling it. The profiles you see there are formed from what both extruders support.
