Thanks Smithy for the advice. Will set the combing to not in skin for my next print.
Also image below is the result of previous print. As you can see, the quality was quite bad at the overhang area although it was only 45 deg and I used 50mm/s printing speed and 100% fan speed.
Other than reducing the print speed further, are there any settings that might affect the overhang quality?
Smithy 1,141
If you mean the lines between your holes, this is combing.
When you set combing to not in skin, then the printer will retract these travels moves.
