Every print core is tested by printing a particular calibration print designed to test the core itself. They can detect things like the sensor being inaccurate, heater not working, other electronic errors, clogged or partially clogged nozzle, leaks, and probably more.
If there were no indications that the core was used that wold be a red flag.
@cav it's exactly what @gr5 said. All the Print Cores go through physical checks as well as functional tests (including printing with it) at the factory before they ship. A little residual filament in the Print Core is definitely normal. The Print Cores are tested with PLA, so anything that's still in the Print Core will purge out the first time you print with it.
gr5 2,210
fbrc8-erin 296
cav 0
that is great thanks to you both for your reply
