It is 20 years ago since I last selected an UPS. A few things I vaguely remember:
- Find the continuous power it has to be able to deliver. See the name-plate on your machine. Multiply that value by 2x, to account for variations, little add-ons like a LED spot, and system-degradation.
- Find the peak-current it has to deliver. Some devices may draw a fairly low continuous average power, but with occasional high peaks. Multiply that peak by 2x, just to be safe.
- Chose the time the UPS has to hold up these values.
- Look up the dimensions and the prices of UPSses. And then fall on your back from astonishment. And reduce your up-time to more realistic and affordable expectations.
Most power-outages do not last longer than a few seconds to minutes. If it lasts much longer, then a failed print probably isn't going to be the worst side-effect you are going to have. So I would go for maybe 20-30 minutes up-time. After a couple of years the batteries will degrade, and you will still have 10-15 minutes.
If you expect frequent power losses for a much longer time, like in California whenever there are high winds, storms, thunders, draughts, freezes, wildfires, no-winds (=no wind power), etc..., then you'd better get a diesel generator too to power your house. The UPS then is to get over the first minutes so the print doesn't abort, and then the diesel takes over. Use non-bio diesel or fuel, because the bio-fuels degrade fast due to algae and bacteria growth, and they lubricate less and are chemically more agressive, shortening the engine-life.
An UPS - even a small one - is also good in case of unstable power, or overvoltages, as it regulates and protects.
😆😂😂 word up!
That´ s what I am afraid of... I heard of people buying a tesla just for using the powercells i.g. one created a ship with that kind of drive.
But that is 100% me. I start out with a small UPS and then I end up with the "diesel"-Version which isn´ t quit economical regarding the printer and the things I print (including the fails).
Anyhow I thank you for your input and your thought about the UPS-calculations and I will keep that in mind when eventually buying one.
The second print went great though (endured 3 days because it was a 100% infill print because of the pressure the thing had to cope with)... t was a decent print!
Greetings
Daniel
PS: Question/Answer regarded as "answered" or"solved" whatever suits you best...
geert_2 556
HaryPlotter 1
😆😂😂 word up!
Greetings
Daniel
