2 minutes ago, Smithy said:Sorry to hear you have some troubles.
Two days ago there was another user with the same problem, but without a solution yet. Can you double check you have selected and configured the correct printer in Cura, just to be sure.
Can you upload a sliced file here, then I can cross check if I am able to load it into my printer.
I double, triple, quadruple checked that I selected the UM2+ Connect. I even downloaded 4.9.0 when we received the three new Ultimakers, because I was still on 4.7.0 (?) which wouldn't show the Connect models. We have UM2 w/ Olsson Blocks, UM2+'s and now these three Connects and a UM3, so I'm always careful with selecting the right printer and print profile.
I have attached a .UFP, .GCode and .3MF I tried to print this afternoon. They appeared to start on my number 1 and 2 UM2C, but not on number 3.
Smithy 1,146
