Posted · Slicing problem with cura
Hi guys. I am in need of some help with cura. When I wanted to print this faucet, the base is like a donut shaped and the middle is meant to be hollow. However, when I sliced it, the whole this becomes a solid. I tried poking the filled part but I think it is a solid and cannot be removed. This is not supports as I did not Rick the supports button. Pls help as soon as possible I want to continue printing well. Thanks for your help.
    Look at the mesh fixes section.  The only thing you might want selected is "union overlapping volumes".  The rest should be de-selected.  If "remove all holes" was selected it was the problem.
    I tried doing what you said but everything was already deselected except for Union overlapping volumes and remove empty first layers. I deselected “remove empty first layers” and it came out the same thing. What else should I check?
    20 minutes ago, GregValiant said:
    Go to "File | Save Project" and (if it isn't proprietary) post the 3mf file here.
    I don’t know how to do that. Is stl file fine? Or do you want the gcode?
    Oh wait I found out. Gimme a sec
    Here it is.
    CE3PRO_Turbine_M24_V1.1.3mf
    I think you did an export.  The only thing in the 3mf was the model and it sliced fine using my printer and settings.  I need the project file (also will be a 3mf) because it will contain your printer, the STL, and your settings.
    In Cura, load the STL and set up the slice.  Then, under the File menu select "Save Project" and create a 3mf file.  Post that file here.
    Urm… I think I did that but I’ll just do it again.
    Here it is. I hope i did it correctly now.
    Turn off "Make overhangs printable".  It's doing just what it says - instead of an overhang you get part structure.
    • Like 2
    Ok. I’ll go home to check. I will update you soon.
    It's in the Experimental section of the settings.  The tooltip should read "DO NOT USE".
    • Thanks 1
    Ohhhhh yess!!!!! How was is even ticked. I didnt even touch the experimental settings. Anyways, yes it works now and thank you very much Greg!
