Thanks both, understood.
I do have some bought packs (Amazon UK). But this (a one-off replacement for a plug), is not included in any of my mixed packs. And my motivation anyway was largely a learning exercise: about screw/bolt threads and also the more general topic of how best to place a part of this sort.
But I'm sold. I'll forget the print project and rummage through my junk box tomorrow, although I rather doubt I'll find one so small in diameter that's at least 17 mm long 😉
Terry
Edited by terrypin
ahoeben 1,965
The most obvious advice is: don't print M3 bolts. You can buy them for very cheap (cheaper than you can print them for if you factor in the cost of the printer, maintenance and your time), and the ones you buy will be much stronger.
No, you cannot remove the shadow.
geert_2 558
Most of the time small printed bolts and nuts won't fit anyway: they are way out of spec. As ahoeben said: buy standard screws (nylon, PC, inox,...), and cut them to length (if required). I do that all the time.
In Europe there are lots of good online suppliers, like RS-components, Skiffy/Essentra, INDI, Farnell,... Or go to a brico-shop.
The only reason to design a custom threaded part, is when there is no standard available. Let's say you invented a nice water gun for your kids in summer, and you want to fit a standard Coca-Cola PET bottle to it as water-supply. Then you could design a custom threaded cap in your gun, so it screws onto standard bottles.
Standard nylon M4 thumbscrews and nuts in a custom design:
