Thanks gr5,
I wasn’t clear enough in my question, sorry for that, but anyway😀
What I mean is: what type of material should I choose after loading the filament on my UMS3… After loading the filamentspool, before forwarding the filament, the machine wants to know (because it doesn’t recognize the material) what type of filament it is…
Which one should I choose? (Ultrafuse 316L is not an option)
hope to hear from you again,
regards
Woezerd
gr5 2,334
1) In cura go to "marketplace" in the upper right corner and choose the center tab (materials) and then BASF and then scroll down to ultrafuse 316L and click "install" and when done restart cura. Is that what you meant by you "downloaded" it?
2) In cura go to PREVIEW mode and near the top click on either left or right core (doesn't matter which) and it pops up a dialog and *there* choose the left core and change the core to "CC 0.6" and change the material to "basf ultrafuse 316L quality", "basf ultrafuse 316L quality".
3) Click on left or right core again near top and uncheck the "enable" box for the right core.
4) Open your STL file in cura and, if you haven't already done this in CAD, select your model, choose the scale tool on the left, uncheck "uniform scaling" and scale the X,Y by one factor and Z by another (see advice from basf for scale factors). Slice it.
5) After printing I believe you leave all support material attached. That comes off after annealing I think.
