It might not be the most elegant solution, but what I usually do when something is acting weird like this in Cura, I just nuke the entire settings folder. Looks like you've already found that folder, but in case someone else sees this the easiest way to get to it is to open Cura and then go to Help->Show Configuration Folder.
Close Cura and then select everything in that folder and delete it. This will cause Cura to re-create all the setting files from scratch which will usually fix things. Of course this will also remove any custom settings you have done.
MattL600 0
Here are my appdata/roaming/ files:
Thanks
cura.zip
