Material Not Selectable on S5 Jabil SEBS 1300 95A
RogueWave
Posted · Material Not Selectable on S5 Jabil SEBS 1300 95A
Jabil is selectable in Cura but does not show on selecting a material on my S5.....there are other third party filament available...uninstalled and installed Jabil but no luck
What's the next step? Thanks
Cura 4.9.1
    The printer is reachable via network? Normally Cura sends the material to the printer during startup of Cura.
    You would try if it helps when you slice a project and sent it to the printer. I think then Cura tries also to send the profile to the printer.
    when I try your suggestion warning ATTENTION materials do not match between Cura and printer settings.
    Their is a override box with a warning printer damage possible with wrong confirmation......
    Should I OVERRIDE?????
    Have you loaded the material? If so, then yes, no problem.
    The material profil in the printer itself is just used during loading (temperature) and during the active leveling when you don't have a material station. All other settings comes from Cura. So even without a material profile you can use any material you want. Just choose the nearest material (temperature wise) during the load process.
    But that's more a workaround, it should work out of the box and Cura normally transfers the profile to the printer. But I currently have no more idea why this is not working.
    Do you have the latest firmware installed on the printer? And is the firewall option in the printer disabled?
    latest firmware installed yesterday and firewall disable
    I tried looking for the folder with third party materials and/or Ultimaker's materials but could not....any idea where?
    You mean in Cura? It should be in the configuration folder. Go to the help menu in Cura, there should be a item with configuration which opens the folder.
    Air Manager on order
    no material station
    Went into configuration folder and uninstall Jabil 1300 95A
    Quick Cura
    started Cura
    message install Jabil and sync
    settings, extruder one, and material shows Jabil and others third party materials for the first time
    set up model select Jabil had to over ride warning
    after 10 minutes of printing it stopped indicating empty spool
    in fact spool full with no tangles whatsoever material easy to pull out by hand
    Resume printing
    Brim printed well and firm to glass plate
    but first layer strings with ok adhesion but not smooth
    Final surface print very good
    first two photos
    Second print the same model moved to different location on build plate
    printer stop again warning empty spool in fact like about
    third photo shows when printing stop
    first layer spots pattern no solid lines …..setting in Cura Cubic
    using my infrared thermometer, old one, bed temperature of 65C material calls for 70C
    Real odd Brim is excellent but first layer is terrible.
    B5353F92-5520-4CF0-A623-D6FA37FEA254.thumb.jpeg.6545d19d144914c34a998a67e210d28e.jpegB5353F92-5520-4CF0-A623-D6FA37FEA254.thumb.jpeg.6545d19d144914c34a998a67e210d28e.jpeg08E76574-AC77-4BFE-9047-68C8BC7B7626.thumb.jpeg.3e1c377832d33e4eae7fbc439cef7f8f.jpeg
    My supplier gave me a refund on the Jabil SEBS 1300 95A filament
    too many odd problems........very glad have a excellent S5 machine which narrows down the problem to others
    Hats Off to development team
