Hi @taikonaught,
I'm sorry to see that you've had this problem for so long.
I wonder why is there no "valid" error code as we see it on the LCD display to be seen on Octoprint?
An UM2 have just a few errors that will stop the printer with a given message:
We have temp probe error, heater error and the three stop switches (X,Y and Z), if my memory serve me right..
In your case I'll think it's either a temp sensor/heater head error, or a temp sensor/heat bed error.
If the temperature drop too much offset during print the printer report temp error, also if the temp sensor have an intermittent connection the same is reported and the printing stop due to this error.
In the LCD display you're asked to go to an Ultimaker web address for guide.
I'm not sure if any of this is reported to Octoprint.
You might also try to use blue tape on bed without using heat on the bed, this in order to eliminate the heat bed problem.
Although, a direct probe intermittent wiring break might still stop the printer.
You may also try to let the printer print without filament (use say 180 deg. C for head), start printing without filament and bed a little offset down. In this situation, the head should easily keep the temperature steady.
Also, this will show if this error have something to do with the height..
Just something to try.
I've also been looking a little to the OLED wiring, but we may wait a little with this.
Good luck.
Thanks
Torgeir
taikonaught 2
i have tried different ways of printing from different gcode.
Printing direct from Cura over USB, tried slicing it in new and old versions of Cura, tried printing via Octoprint and Pronterface, all wit the same result.
Any clues? Anyone?
