Posted · Difficulty removing support from small part
Could the experts recommend what settings I should have used for this 16 minute print please? My screenshot hopefully shows the problem details clearly. In summary, I enabled support default settings but after several minutes with a tiny screwdriver I was still unable to get it off.
    Posted (edited) · Difficulty removing support from small part
    Thanks, I'll try the first of those. But I don't know what you mean by the second? In the support settings I see no reference to that? Aren't the default settings supposed to allow 'break away' by the user?
    If it helps, here's a screenshot showing all 52 lines:
    Hmm, that image looks hard to read. Here's the list as text (without the default values):
    Generate Support
    Support Structure
    Support Placement
    Support Overhang Angle
    Support Pattern
    Support Wall Line Count
    Connect Support ZigZags
    Support Density
    Support Line Distance
    Initial Layer Support Line Distance
    Support Infill Line Directions
    Enable  Support Brim
    Support Brim Width
    Support Brim Line Count
    Support Z Distance
    Support Top Distance
    Support Bottom Distance
    Support X/Y Distance
    Support Distance Priority
    Support Stair Step Height
    Support Stair Step Maximum Width
    Support Stair Step Minimum Slope Angle
    Support Join Distance
    Support Horizontal Expansion
    Support Infill Layer Thickness
    Gradual Support Infill Steps
    Enable Support Interface
    Enable Support Roof
    Enable Support Floor
    Support Interface Thickness
    Support Roof Thickness
    Support FloorThickness
    Support Interface Resolution
    Support Interface Density
    Support Roof Density
    Support Roof Line Distance
    Support Floor Density
    Support Floor Line Distance
    Support Interface Pattern
    Support Roof Pattern
    Support Floor Pattern
    Minimum Support Interface Area
    Minimum Support Roof Area
    Minimum Support Floor Area
    Support Interface Horizontal Expansion
    Support Roof Horizontal Expansion
    Support Floor Horizontal Expansion
    Support Interface Line Directions
    Support Roof Line Directions
    Support Floor Line Directions
    Fan Speed Override
    Use Towers
    Edited by terrypin
    More info
    Apologies terrypin....I wasn't clear....
    Breakaway material is a specific type of material. https://ultimaker.com/materials/breakaway
    The settings of which are within Cura.......she below screenshot.
    This is a screenshot of something that is printing right now:
    We are using PLA material, and this is very easy to remove. The image also shows what settings we're using.
    Edited by Carbon
    Terry,  What I do is create some small thin as possible "pillars"(green) to raise my part off the print bed and add "enable support interface" in the support menu this adds a thin layer under your part.
    there will be support under the flat that is currently on the print bed, but I use a utility knife and it peels right off.
    Hope this helps,
    Frank
    Great idea, thanks Frank, I'll try that when I next print a similarly challenging part.
    Terry
          • Heart
        • 7 replies
