Ultimaker Cura needs a functioning firmware on the printer in order to update the firmware. If there is no connection between the printer and Cura, then Cura will not be able to flash the firmware.
- 1
Here's a dedicated utility to upload a .hex file to the controller:
Thanks. The XLoader software worked for the motherboard, but I still get get the firmware on my Artillery printer. I keep getting a communications error. Any ideas of what could be causing this? Thanks.
Smithy 1,144
I never used the USB function of Cura and the implementation of it quite old and wasn't touched for years, because Ultimaker printers don't need USB connectivity and printing via USB is also not the best idea.
Regarding your problem, what's the official way from your vendor to update the firmware? I guess they provide a tool to update the firmware?
Any other 3rd party software you can use to update your printer?
