Hey guys,
First of all, thankyou so much for all of your help and fast responses. New to printing and modelling its all very intimidating and overwhelming but im learning fast and i cant tell you how much i appreciate the responses!
I ended up going back to blender, did a lot of undo, deletes and googles but eventually managed to make the model with some thickness (although i cheated by duplicating the initial cube and sizing it down a little). Finally got a decent print of this for my friend's birthday.
Thanks again!
GregValiant 1,112
You can see in the view from Blender that the letters have some depth. The walls look very thin and likely can't be printed. Your outer skin on the model needs some thickness.
I don't know Blender but generally any object must exist in three dimensions to print. When you have a single surface it doesn't qualify since it has no Z dimension. Now if you could extrude that surface then you might have something workable.
