Hi @Disobeyed,
Sorry to hear that..
When you said white led, are you talking about the light strip inside the printer?
So to the amber light, is this the one on the main PCB?
There is "several" LED lights, so we need to know the correct one.
There is three "amber/red" lights, two yellow and one green LED on the main PCB.
Here is the PCB layout with associated components:
Please indicate here.
Thanks
Torgeir
Smithy 1,145
Did you just worked on the print head or also on the bottom of the printer?
You have probably shortened something during your work. So please ALWAYS turn off the printer and disconnect the power before you start working on it.
If you opened the cover on the bottom then maybe a connector is not in place anymore.
Wir haben auch einen Deutschen Bereich falls dir das lieber ist. 🙂 (We also have a German section)
