Possible to force Cura to generate slices that are greater than or equal to the 3D model volume?
Posted
· Possible to force Cura to generate slices that are greater than or equal to the 3D model volume?
Look for 'horizontal expansion.' That has saved me many times with just a very small expansion. Note that it does not expand in the Z axis. Just the Y and X.
Posted
Thanks! That looks like it will do the job, though the skeleton might look a little 'chubby', if such a thing is possible. In the mean time I actually got it to work by opening the STL in blender and the expanding the swords width by transforming it in the X-direction whilst using the camera view as the reference.
Posted
Ahhhh, ok, so you know a 3|D program. Bravo! As for the skeleton being 'chubby', try to use very small increments of horizontal expansion if you need it. I have gotten away with .05mm before. Just enough to beef up the size, but not really enough to notice.
You can also go into 'per model settings' and apply almost any setting per model itself. Say select the sword and perform one tiny amount and then select the skeleton and apply a different amount.
Posted
(edited)
@kmanstudios / @GregValiantthanks, I have to admit that was putting off opening Blender, I hadn't used it since version 2.6 a few years ago and I wasn't convinced I could really remember how to do anything. Turns out it's a bit like riding a bike, everything came back pretty fast, and any tools that I knew I wanted to use but couldn't find were easily locatable with a quick Google.
I didn't know about the 'per model settings', good tip, thanks!
Edited by curaMatt
kmanstudios 1,120
curaMatt 1
kmanstudios 1,120
GregValiant 1,342
Yep, thinking outside the box. I love a good well thought out workaround.
(Of course it has to actually work or I'll take away your attaboy.)
curaMatt 1
@kmanstudios / @GregValiant thanks, I have to admit that was putting off opening Blender, I hadn't used it since version 2.6 a few years ago and I wasn't convinced I could really remember how to do anything. Turns out it's a bit like riding a bike, everything came back pretty fast, and any tools that I knew I wanted to use but couldn't find were easily locatable with a quick Google.
Edited by curaMattLink to post
