Go to left side of screen in PREPARE mode. Click on your printer, then do "manage printers" then "machine settings", Uncheck "origin at center". That's likely the problem.
Also check the dimensions of your bed - for example, if it says your bed is 100mm wide but it is actually 200mm then fix this. This shouldn't be the dimension of the glass/print surface but the limit of travel for the printer.
gr5 2,332
