I looked into the functions of the Cura Master you told me about, but I didn't have the functions I needed
Isn't there a 3D printer that has two heaters inside one extruder?
Of course, the temperature of the two heaters must be set differently
If not, would I have no choice but to revise Cura's code myself?
ahoeben 1,968
1. Yes. @burtoogle maintains his own fork of Cura, which has many features that Ultimaker Cura does not have.
See https://github.com/smartavionics/Cura/releases
2. This is already implemented in Ultimaker Cura, though it is hidden and you basically need the Printer Settings plugin to access it. However, the functionality is part of the aforementioned fork by @burtoogle
ARSTAR 1
Thank you very much.
I don't know if it's the function I wanted.
I'll give it a try.
