I have never even heard of Chitubox, so no.
However, I do have some other slicers on this computer. None of them caused issues with 4.8 though
Could you then share your log from 4.10? You can find your log in the configuration folder. Go to help - show configuration folder.
I have already uninstalled 4.10 and reinstalled 4.8 so I can print.
Will the log file from 4.10 have been saved?
Can I have both 4.8 and 4.10 installed so that I can get a new error log file without repeatedly installing and uninstalling?
On 7/16/2021 at 5:22 PM, ADmakes said:OK, I reinstalled 4.10
Here is the screenshot and log file
thanks for your help
This is caused by an outdated plugin. Please update the custom job prefix plugin. A fix for this issue has been out for months now.
fvrmr 73
Hi @ADmakes do you have Chitubox installed? If so that is causing this.
See here how to solve this: https://support.ultimaker.com/hc/en-us/articles/4402996140946-Ultimaker-Cura-crashes-when-opening-any-file
