I do understand what you mean, but I don't know if there is a setting for that. What could also help is making the walls and top shell thicker.
But if you are going to cast concrete anyway, what about using the model as a base for making a mould, and cast the whole model in concrete? So you have a fully concrete model without plastic?
In a CAD-editor, subtract the model from a block, so you have the inverse hollow shape of the model. Cut that block into two parts (or more if required), so the cast can be released from it later on. Add alignment features so both halves snap in place. Then add clamping features, and add pouring and venting holes. Think these over carefully. Smooth the inside, spray mould-release spray, and you have a mould that you can use for multiple concrete casts. This combines the advantages of 3D-printing with casting, and you have the stone-like texture of cement in the casts. You could add marble or other powder to the cement mix for additional effects.
On the internet you can find a lot of good tutorial videos on mould making and casting.
geert_2 558
