Posted · support outer wall
If you do remove that outer wall then those very thin walls may fall over.
There are several different support pattern options:
grid, lines, etc.  Did you play with that?  It looks like you chose lines
Well I tried to duplicate your support structure and I can't.  I tried a whole bunch of support settings and mine don't have those walls.
Please post your project file (it will contain your model, your printer settings, your profile, and your setting overrides).  Go to menu "file" "save project..." and post that file here.  Also what version of Cura are you using as I have to use the same version or newer otherwise the project file won't open for me.
    • 1 year later...
