Fiddle with any setting, or move any object. I've updated the code to fix the minor issue.
I was unsure where to put it, I did not like it as a setting (as none of the settings go over multiple objects) but I also did not want to hide it away all the way in the preferences.
IRobertI 520
Man, it took me a while to find that option... Why is it in a "Tool" menu instead of together with all the other settings? Terribly counter intuitive IMHO. Oh well.
I gave it a try and it looks like changing that setting doesn't trigger a re-slice. Hopefully daid sees this and fixes that for the next version. In the mean time you can just fiddle with any other setting and it should force a re-slice.
