GregValiant 956
Each nozzle has a file in "resources\variants". You can copy one of the Ender 3 nozzle files, rename it to match the naming format, and change a couple of lines in the file using Notepad. Next time you start Cura it should be present in the dropdown list. Be careful when altering the file as Python is fussy about punctuation and spacing. If you get a " corrupt file" warning, c!ose that warning, get out of Cura, and try again.
Smithy 1,134
If a specific nozzle size is available or not, depends on your printer profile. The one who created the profile just configured nozzles up to 1mm but not more.
But you can also just set the line width to 1.2 which should do the same, regardless of the selected nozzle size from the drop down.
