Please see the attached project file.
- Look around layer 10 to see the issue. The only parameter you need to change is checking/unchecking "Mold"
- Slicing with Mold CHECKED creates the desired fully dense support with no Z distance between the support and part/raft.
- Slicing with Mold UNCHECKED reverts to a sparse support with a visible Z distance between support and part/raft.
Thank you.
gr5 2,230
Could you please post a project file? A project file will include your STL (feel free to use an example one if yours is proprietary). Include it such that we only have to check or uncheck Mold (and reslice) to see the difference.
Project files contain your model(s) position and scale of model, printer (machine) settings, profile, profile changes.
To get the project file do menu "file" "save project"
