UM3E Firmware update issue
Oj00
Posted · UM3E Firmware update issue
My UM3 and UM3E have not been able to update firmware via network for a while. When I tried to update via a memory stick and upon rebooting both printers froze with vertical lines on the screen. I restarted both printers, the UM3 had updated and now updates via the network. But the UM3E still remains at its previous version and even after a midway update to 5.2.17.20 I still cant update to 6.2.2 as it comes up with the vertical lines again.
Any ideas?
    My bad, I must have picked up the wrong stick when I was running through all the machines in farm. Just seen the notice that UM3 is in maintenance mode.
