GregValiant 1,346
As AHoeben says you can add a Custom FFF printer. An option would be to add a different Creality printer and change the build size in the Machine Settings.
Creality printers use their own firmware that is a version of Marlin. Most other settings (accel, jerk, max feedrates, etc) are common throughout their line of printers. If the 200B has auto bed leveling it would need to be accounted for in the StartUp G-Code.
If you were to add an Ender 3 and rename it, and then change the build size to 200x200x200 you should have a workable starting place. You can always add a Custom FFF as an option.
- 1
ahoeben 1,986
Only if someone submits a profile for it. Ultimaker does not create third party printer profiles, but will accept "pull requests" from community members or printer manufacturers who have written a working printer profile for their printer(s).
ahoeben 1,986
You could use the "Custom FFF Printer" option.
