Cura - Meta Data - Field Name?
Carbon
Posted (edited) · Cura - Meta Data - Field Name?
That list is a big help, thank you ahoeben 👍
wall_line_width_x does not appear in the Metadata I have.....
I'm trying to change the "Light Green" background to "Black".....
Edited by Carbon
    Posted · Cura - Meta Data - Field Name?
    I completely misunderstood what you were trying to do. You are making a "theme". I thought you were making a color scheme in layerview, and somehow wanted to access the value of the particular setting you pointed to.
    On 8/24/2021 at 11:46 AM, nallath said:
    It's called "setting_control"
    Managed to do it, thanks.....👍
    Changed the logo on the back / base of the buildplate too:
    Edited by Carbon
        • 27 replies
