Posted
(edited)
· Cura Preferences Instability with Plugin
The addPreference method has to be run each time Cura starts, before you access the preference with getValue/setValue.
Saving the preference values to file is done automatically. You don't have to tell Cura to do so.
If you use setValue to set the preference to its default value, the value may be remove from the cura.cfg file. But since you must specify that default on each startup of Cura with the addPreference method, this works fine; if there is no value in cura.cfg, then the default value is used.
Edited by ahoeben
ahoeben 1,721
Edited by ahoebenLink to post
