We don't make the profiles for third party printers (they are contributed to us by community members) so we can't guarantee that the numbers they contain are actually correct.
This is not the same as seeing the "correct" time in the Cura window, but maybe it's something you can use.
I made a request for a plugin about a year ago and one of the contributors to Cura adapted an existing one and came up with "ShowProgress.py" that I'll attach as a zip file. I like it because it has a "speed factor" in it for the print time. If Cura tells you a print will take 1 hr and you know from experience that it will take 1.25 hours then the fudge factor would be 1/1.25 = 0.8.
If your firmware supports M117 then "1/240 | ET 4H03M" will appear on the LCD at layer changes. The Cura "TIME:" line is not affected and will always show the print time that Cura calculated in total seconds.
(I run Windows so adjust accordingly for Linux or Mac) Unzip the file and copy it to:
"...\Ultimaker Cura 4.x.x\plugins\PostProcessingPlugin\scripts. It will show up as a Post Processing Script the next time you start Cura. I found that for my printer a Fudge Factor of 1.1 works well. I don't see it when I slice, but it shows up on the LCD during a print and counts down to the finish while the layers count up.
nallath 1,123
Often it's because the acceleration / jerk is not setup correctly in Cura. It's an issue that people run into more often. See https://3dprinting.stackexchange.com/questions/4066/estimating-printing-time-from-cura
GregValiant 1,287
ShowProgress.zip
