GregValiant 1,112
You might be able to fix it using this repair site https://formware.co/OnlineStlRepair. Upload the file and when it's ready you will get a report of the errors and hopefully the file will be fixed (not all can be repaired). Then download the repaired file. I've used them a few times with good results and it's free.
Labern 774
Hi there.
It looks like the model is not a solid model and there may be an open face or have errors in it.
Some programs like SketchUp allow you to draw faces that don't form a solid model. Which means that if you were to fill it with water it would leak.
