Posted · Infill showing through print
42 minutes ago, nallath said:
in that case Ithink your only option is to increase the number of walls
Ok but I already have a wall thick mess of 1.6 and have 4 walls
    It also depends on the kind of material/filament you use. Some brands are a bit translucent and then you see more infill. As nallath said, increase the walls and you should be fine.
    Ok thank you
