It looks like you're having the problem in the same area of the build surface.. just a suggestion: try making a small test part and place it in Cura right in the area where you're having the problem. That'll help find the root cause.
Hi JTMD,
But the location of problem is random as you can see in the 2 pictures.
I will find another glass bed.
8 hours ago, duyle said:Hi JTMD,
it's not *exactly* random.. mine was the same way.. not always exactly in the same spot but usually in the same general area. No problems after the glass change.
Smithy 1,088
The glue stick should not be the problem, but follow this advice to get an even layer:
https://www.youtube.com/watch?v=i8PGtv0ueGg
