Ultimaker S5 - wiggle on printhead in Y-axis
joelbrande
Posted · Ultimaker S5 - wiggle on printhead in Y-axis
Hello,
I recently noticed allot of wiggle in the printhead on the Y-axis. Is this normal?
It looks like the printhead is connected with 4 bolts (see picture).
I checked the manual to look if there are any specification how tight the bolts need to be in Nm.
But I couldn't find any reference.
    So I tightened the 4 bolts a little bit on the printhead.
    It reduced the play in the printhead allot in the Y-axis direction.
    This is my first printer so i'm not sure if i made things better or worse.
    Anyone else ever had to tighten these?
    Guess the worst that could happen is that i screw up the bearings.
    Hello
    In practice, the observation that X has less play than Y is normal for this printhead. Because inside, the axle has one bearing less in the Y direction.
    Here is a picture I took during a maintenance / repair of the printer.  A bearing in the middle.
    I also tightened it a little on mine. Theoretically, you can't damage the bearing because it is positively locked in a recess in the cover. Even after tightening, the bearing still has more play than the other one.
    As a constructor, this can make you think. But what I find more important is that it works like this.
    Many greetings
        • 29 replies
