I used the X5SA pro 400 profile and added the 2nd extruder in the definitions so that I could have 2 extruders. If I override extruders setting I can a print a model with either extruder using Cura.
I believe I also tried a custom printer and saw same visual problem with Cura.
GregValiant 1,342
I don't see a definition file for your "-2E" printer. Did you get a definition file from TronXY?
I ask because I could load the model from the 3mf file but Cura didn't like your printer. Using my own dual extruder definition the preview looks right and the gcode looks good also.
