What's the reason for that? Seems to me that's pretty dangerous thing to do. Say, for whatever reason, the printer looses steps and thinks it's further away from an edge than it really is, then when it tries to move in that direction it will slam into the side of the machine thinking it still has room to move.
My Marlin builder has "use endstops only for homing" enabled by default. So your endstops are only used for homing.
I loaded a small test print into your software. It immediately headed for the left front of the machine and did what Robert said, it slammed into the front and wanted to keep going...I shut the machine off, moved the head back away from the sides and turned it back on, the software kept going and moved the head to the center, leveled the bed and starting printing....at any rate from the setup instructions it says to make sure the limit switches work my manually pushing while the head is moving and none of them do.....should I have unchecked the 'enable homing' on your build software?
Interference from the motors on the end switches can really ruin a long print.What's the reason for that? Seems to me that's pretty dangerous thing to do. Say, for whatever reason, the printer looses steps and thinks it's further away from an edge than it really is, then when it tries to move in that direction it will slam into the side of the machine thinking it still has room to move.
You should have unchecked "Endstops only for homing". It's not that recommended to go to a custom build firmware before you know how to operate your machine properly, and everything works hardware wise. UNLESS...
The firmware that's shipped with SkeinPyPy-Beta4 (Cura) has the endstops always enabled, exactly to prevent damage to your machine. It's also checked, and verified to work. So that's always a safe firmware to switch to.
The Marlin_Builder was more intended for experienced users that want to customize their firmware a bit. Without going trough all the Arduino loopholes. When I update to new Marlin versions (as I try to keep it up with the development) it might break from time to time.
Ok thanks for that info....I didn't realize i was using custom firmware....I loaded up your Cura and got halfway thru the one time only wizard and it said it couldn't set the temp...so I went ahead anyway...loaded up an stl file, sliced and diced it, loaded that up into printrun, heated everything up and hit print...it did beautiful..!! except for one thing...all my test models are printing out to about 1/5 scale.....under your model config it does say scale: 1 so i figured 1inch would come out 1inch...but it doesn't....iam using autocad R2007 for 3D and my stls....would that make a difference?...or any idea why the scale is so much different.....thanks again...
Compile using mm and not using inches. The Ultimaker uses the metric system.
will do....thanks
Daid 304
