GregValiant 1,110
Its Google taking over the world.
Use file explorer and go to your downloads folder. If you didn't discard it then the file will be there with a weird name like blahblah.download. Change the name to whatever you want and make sure it has a .3mf extension. This happens to me all the time now as I download a lot of project files and gcode files to check them. It started about 3 months ago.
1
GregValiant 1,110
When that STL file was created it was made out of two pieces. A hollow base and a hollow upper "body". Cura can only follow the model and there is nothing inside to print.
EDIT: News flash here. We may have found a use for "Remove All Holes". It's in Mesh Fixes. Click on that and then set up your walls and infill.
I created the attached 3mf file using a Monoprice printer. When you open the 3mf file it will ask you if you want up update your Monoprice printer or create a new one. I suggest you choose to create a new one so you don't mess up any customizing you may have done to your printer in Cura.
jewerly_ring_bust_display.3mf
Edited by GregValiantLink to post
Smggems 0
The file pops on my browsers (Chrome and Microsoft) as dangerous and wont let me download
