Is this a Z-seam issue? It rather looks like underextrusion to me? Just a guess, I don't know your printer.
Generally, printing slow, in very thin layers, near the lower edge of the temp range (=to prevent overheating and decomposing of the filament, due to sitting in the nozzle for a long time), tends to give the best results, in my experience. Also, in addition to the above suggestions, set all speeds to the same value (inner and outer wall, infill), so that the flow through the nozzle is as constant as possible. Wild speed variations cause wild flow variations, and thus temperature variations, and a lagging in nozzle pressure (=overpressure at the end of a fast traject, and underpressure at the start of it).
GregValiant 1,110
The print head is taking a while to build up pressure to print. Turn off "Retract at Layer Change" and set combing to "None" and see how it goes.
If you load that part in Cura and use "File | Save Project" you can post the 3mf file here. It will contain the part and your printer as well as your settings and is easier to debug.
Starting about this time of year the "cookie cutter" problems start coming in here. Thin walled models have their own set of problems so being able to see the model is a good thing.
