GregValiant 1,145
That model hates "Cubic Subdivision" infill. Grid and Triangles and a couple of others looked good, but I'm not sure what you are looking for.
That mesh modifier you have over the "smoke stack" is better at 22 x 22 and moved a bit. It's cutting off a piece of the stack.
The large mesh modifier doesn't appear to have any settings enabled.
1
GregValiant 1,145
You will need to use the File | Save Project command and post the 3mf file here. Without seeing your settings it would just be guesswork.
tim_t 0
weird_infill.3mf
Here is the 3mf file. You should shift it maybe a little bit so it fits within the build volume in order to slice it.
The weird thing happens in the middle circle in the infill lines. So layer 80 or layer 60 or which layer you prefer where it prints the infill circle in the middle.
I kind of understand the slice program, because I changed the infill density from 20% to 80%, so it goes over the lines 4 times instead of 1. But this leads to overextrusion in the print, while it should just make more triangles.
Thanks in advance!
