After i acknowledge the error message and i click on resume print it continues without any problem. I also just cleaned the cores before started this print. I will try to turn off the flow sensor. Can that cause any troubles?
Well definitely read what Ultimaker has to say:
https://support.ultimaker.com/hc/en-us/articles/360011706239
It amazes me that the printer says to go to ultimaker.com/ER65 yet very rarely do people seem to do it.
The filament sensor gets confused if you are printing very flexible filaments. Very rubbery filaments. Also having it only 2.6mm diameter could be the issue. I'd just turn off the sensor. 99% of printers out there don't have a filament sensor and they do fine. It's easy to disable from the menu system on the printer.
Yeah well at least I cleaned some parts:DD But it didn't solve my problem.
I managed to make better filament just now. But I have a print on, so I turned off the flow sensor to finish it with the current filament, also the print looks good for me, so I dont want to abort it.
It is just bad I have to be here to resume in case it stops:D But we will see without the sensor what happens.
1
Smithy 1,145
Diameter between 2,6 and 3 is not really consistent, so I guess the flow sensor has some troubles with it. You can try if it is better when you turn off the flow sensor in the printers menu.
Or your filament is clogging the print core in longer print jobs and therefore the flow sensor throws an error.
