Problem discovered and solved!
Thanks for all the help guys, but check this out...
After sending a couple kilograms of filament through my first nozzle (I did not really think they wore out that fast), I guess it gave up the ghost all at once. The new one has a much pointy-er nose on it and is spewing hot plastic like a finely controlled champ.
Fat Bottoms, girls...
Edited by TopQuark
ahoeben 1,723
The best way to reset Cura is to go to "Help -> Show configuration folder". Then close Cura, and remove all the files from the configuration folder that opened, but leave the empty folder in place. Then restart Cura.
