Thanks for the info. I will up the heated chamber temp as recommended. I increased the printing temp to 270 and this has massively improved adhesion.
I looked through the material TDS and was going to suggest Tough PLA to the client.
Thanks,
Carl
TimonR 21
Hi @CarlGregg,
Unfortunately your observations is also what we've seen internally. For ABS to have proper layer adhesion, it simply helps to have a heated chamber around 80-90C to relieve stresses during printing.
To give you some data:
Tensile strength in XY (ASTM D3039) = 38 MPa
Tensile strength in Z (ASTM D3039) = 19 MPa
So basically we have half of the tensile strength in the Z direction, using an AA0.4 printcore with 0.15 layer height and engineering profiles using Ultimaker ABS.
Another option could be to look into the requirements from your customers and find a different material (if that's acceptable). For example, Tough PLA has exceptional Z strength of 33 MPa (if that's of importance to you). If thermal resistance of 75C is needed, PETG or CPE could be another good option.
Hope this helps
