Is this the folder needed?ConfigurationMenu.zip
I cannot boot cura.
The crash send report message box does not allow me to click the help dropdown
I'ts located here: C:\Users\<your username>\AppData\Roaming\cura\<Cura version>\
1
Nope, that's only a part of it.
21 hours ago, djthuma said:This helpful?
No. You seem to have gotten the folder from C:\Users\<your username>\AppData\Local
instead of C:\Users\<your username>\AppData\Roaming
To diagnose this, we really need the folder from Roaming, as @nallath requested.
4.12.zipGot the correct roaming folder now.
can I simply delete a profile? Or will I need to redownload or edit a script?
Thank you
Ah, I remembered correctly, this has been fixed for 4.13
If you remove the active_machine line from cura.cfg (line 21) it should at least start up again.
- 2 months later...
I try 4.13.1 today and it crash, only ultimaker profile work :), i have Ender 3- i try to delete every old profile -no susses.
i find a problem, my Windows User name was with non-Latin characters.
nallath 1,100
Huh. I thought I had fixed that.
Could you share your configuration folder?
