Closed Body Support Problem
Protheus
Posted · Closed Body Support Problem
i have a huge problem with a (almost) closed body print and its support.
I want to print a case for my Zigbee Lan Gateway (attached). The walls are printed really good but as it gets to the support the whole print it getting a chaos. The printer tried to print the support in the air (about 1mm from the ground) but i set the "Support Z Distance to 0.2 mm.
I'm not printing that much, but till now the supports where printed ok. So i have no clue what's the problem.
I tried 5 prints with a little different settings and changed to a new nozzle. I leveled the printer (Artillery X1) 3 times but the result was every time the same.
I attached the whole profile.
Does anyone have a hint?
Best Regards.
Protheus
Screenshot - 2021-12-18 15_28_10-Artillery SW X1@Construct01 - Repetier-Server Pro 1.1.2.png
Body by Alex.F.stl PETG (Geetech) Cura Profile.curaprofile
    Please save a project using File -> Save project... That way we know exactly what settings you use, what printer, etc. Unfortunately there is little to nothing I can tell from the low quality photo you attached.
