GregValiant 1,288
A lot of travel moves can be generated with certain combinations of settings. Where the Z seam is in relation to the layer start X Y location, the combing mode, monotonic lines, etc.
Do you have "Fill Gaps Between Walls" turned to "Everywhere"?
On a "U" shaped section the combing moves will want to stay over the part rather than jump the short gap. The nozzle may run around the back of the horseshoe a couple of times to do it's job. It can be really annoying.
For larger models and if Z hops are NOT being used then the post-processor Retract Continue can help the nozzle from oozing on long combing moves. That helps extrusion starts after combing.
"U" shaped sections do generate a lot of movement. On the other hand, on that model, pretty much however I set Cura up the print time was 1hr 10min.
You don't have a real need for the infill to provide strength. You can try setting the "Infill Layer Height" to 2X Layer Height. The infill will go down every other layer but at 2X flow so you might have to slow the infill down. There are a lot less retractions though.
You can play with "Gradual Infill Steps" too. I use that when all my infill has to do is hold up a roof so it can print.
- 1
lancebaa 0
Small update with some of my troubleshooting...
After looking through CuraEngine source, I figured out that the small polygons must have been part of a larger polygon at slice time, and yep. Small polygons are removed *before* thin walls are culled. If I enable thin walls, the features connect on those two layers (see screenshot), so clearly at slice time it was one big polygon on each of the two layers.
However, the whole point of me wanting to exclude small polygons is to avoid travels and retraction. Even with the thin walls (one of them VERY thin) there are still travels and retractions for some reason.
Not sure what the solution should be, but IMO small polygons should be removed after thin walls are culled (if thin walls are turned off). I realize that probably creates other problems, though.
