Thanks Smithy,
as I said I already tried everything mentioned in the according support document. I will relevel to 14mm and try a different place.
I highly doubt that it will change something because the printer run well for some 200 hours right now without any problems. And nothing changed. Not the environment (electrical interferences) nor the actual printer setup (build plate too low or too high).
Keep you posted.
Thanks
Michael
Smithy 1,131
Your reseller is responsible for support, but you can also open a support ticket here: https://support.ultimaker.com/hc/en-us/requests/new which will be forwarded to a reseller of your country.
There are several reasons why active leveling fails, here some hints:
In the printer menu there is also a test routine to check the sensor.
