3 minutes ago, GregValiant said:A picture is worth a thousand words.
The print might be warping and losing bed adhesion. The bed adhesion could just have been insufficient from the start. The nozzle could be hitting the print and breaking it loose.
When you say "helper" what do you mean...were you using a tower? or was there support in the way?
The "Helper" in this instance is the cyan line in this picture. It's somehow melting together with the main print
GregValiant 1,364
