Posted · Ultimaker S5 Firmware 7.0.1 Bug
When doing an XY calibration, if the filament for print core 2 has a feeding issue it will give the normal error message. However after clearing the message and trying to abort the calibration print, the print head moves to the front right corner and the printer hangs with the print bed showing 85 degrees. The temperature does not change and the printer hangs until the power is cycled.
